dome light always on, not the switch
Old Nov 20, 2006 | 10:59 AM
otter360's Avatar
otter360 is an unknown quantity at this point
Default dome light always on, not the switch
96 4x4 lots of miles
dome and floor board light will not go off after the usual time delay after the doors are shut. All lights should go out after 2 sec when doors are locked, and then about 30 seconds if doors remain unlocked.
When I sit inside the car and close the doors, after 30 sec I can hear a "module" click under the dash which usually makes the lights go out but instead, the lights remain on.
Here's the clencher.... the light timers/module works during the daylight... but fails to turn off the lights at night (even though I still hear the "click" at night). I'm guessing the problem is temperature dependent ie. colder temps at night are having some thermal expansion effect on some part in the electrical components of the lighting system.
Any clues as to where the failure is at?
Thanks very much... I'm getting tired of disconnecting the neg battery cable every time I finish driving for the day.
Otter
Old Nov 20, 2006 | 12:46 PM
Chevy Lover's Avatar
Default RE: dome light always on, not the switch
I'm not sure what the problem is, so I'd start with removing the door switches one at a time, (perhaps an internal short in a switch)
Old Aug 5, 2008 | 06:47 PM
96jimmy4x4in's Avatar
96jimmy4x4in is an unknown quantity at this point
hi i own a 1996 gmc jimmy 4x4 sle w. 4 doors and i was wondering if i had floor lights on it.. the dome lights on the roof and the courtesy lights on the roof work just fine. i was wondering if i had lights on the floor though and if i do can someone send me pics to show me
Old Aug 5, 2008 | 08:54 PM
Yooper's Avatar
Yooper is an unknown quantity at this point
Check to see if your door switch is broken off.
Old Aug 28, 2008 | 10:53 AM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
in my 97 there is a sensor in the front 2 door handles that when the handle is lifted the lights come on.. also there are door pins in the dash... in my 97 the door pins were only used for that buzzer when you leave you keys in the ignition. so my guess is there is a sensor on or near the door latch in the doors..
Old Aug 28, 2008 | 10:54 AM
97ssblazer's Avatar
also in the rear hatch... rty flipping that switch in the roof of the back cargo area... that should eliminate the hatcha and rear glass from the situation..
elkram
Nov 1, 2012 11:28 PM
captaingo
Jun 27, 2011 01:18 PM
carpboy
Nov 7, 2010 02:29 PM
David Hineline
May 25, 2010 04:29 AM
necropenetrator
Oct 26, 2009 09:55 AM
