dont want to go
Old 11-30-2013, 07:00 AM
bugkiller's Avatar
bugkiller is on a distinguished road
Unhappy dont want to go
hi all newbee here. ok i have a 2000 blazer changed fuel pump about 1 month ago fixed all problems. now when running and it gets to 2500-3000 rpm it seems like it is clogh up . deep grawl sound and no power then spits out and stalls .I NEED HELP PLEASE . THANK YOU
Old 11-30-2013, 07:48 AM
LannyL81's Avatar
LannyL81 is on a distinguished road
check the fuel pressure; do a search here and you will find all the details.
Old 11-30-2013, 08:02 AM
rriddle3's Avatar
Also check for a plugged catalytic converter.
Old 11-30-2013, 08:29 AM
LannyL81's Avatar
Yep...as rriddle3 says. Remove the pre-cat O2 sensor with engine cold. If possible put something to deflect the hot exhaust from hitting the underside.
Start engine and see if any difference. If so, then cat is plugged...replace. Best is to replace entire pre-cat, cat and cross-over assembly, but you can also just replace the cat by cutting out and welding one in. Trouble is the pre-cat could also be plugged-up.
Old 11-30-2013, 11:41 AM
bugkiller's Avatar
now it hardly starts and runs.will not get over 1500 rpms with out stalling. have to let it cool to check the cat i guess??????????
Old 11-30-2013, 11:47 AM
newguy's Avatar
What brand pump?
Old 11-30-2013, 12:02 PM
bugkiller's Avatar
it is a delpi been fine for 4 weeks now
Old 11-30-2013, 02:13 PM
newguy's Avatar
ok have a hard time thinking its the pump now, maybe cat or fuel filter
Old 11-30-2013, 02:14 PM
newguy's Avatar
Also would do a leak down again, when I put my pump in I sprung a small leak just from moving things around
Old 12-01-2013, 11:14 AM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Did you change the fuel filter on the frame when you did the pump?
Quick Reply: dont want to go
