door hinges; roller and pin
Old 08-30-2010 | 08:39 PM
ant2297's Avatar
ant2297 is an unknown quantity at this point
Default door hinges; roller and pin
I need to replace the door hinges on the front doors of my vehicle. I also need to replace the roller where the door hold open arm rolls against. I did some research on the internet, and I can not find the roller anywhere, but i did find the hinges. And if im correct about there being a pin that holds the roller from falling, I found that also, but the dealerships only sell them? I seen online that if the pin is heated with a torch it can be removed, is that the correct way to replace the roller? Anyway I need help on finding out the parts exact name(the roller and pin) and where I can find it. Thanks.
Old 08-30-2010 | 11:05 PM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
I'm thinking the roller will be a dealer only item, unless you go to the junkyard and pull one.
As for how to get the pins and bushing out, there are plenty of threads covering that procedure on here. If you end up having a problem, by all means, ask how to solve it.
Old 08-30-2010 | 11:07 PM
Is the roller itself actually bad or is the pin that it rides on bad. If it is the pin, it sounds like you will need to replace the entire hinge which will require drilling/cutting/welding.
Old 08-30-2010 | 11:12 PM
ant2297's Avatar
Its the actual roller. I have never greased them before and they started to flatten on one side due to the friction on the arm against it. I just found the whole pin online, but not just the roller. Is it possible to just buy the roller?
Old 09-02-2010 | 03:15 PM
ant2297's Avatar
Please help I want to fix this ASAP.
Old 09-02-2010 | 03:47 PM
I do not know if the roller itself is available separately, but the dealer parts counter is where I would start.
renfro667
07-22-2019 02:50 PM
BlueDevils
09-29-2015 02:31 PM
MoneyPit99BlazerLT
01-21-2014 11:40 PM
bluesjam99
02-15-2007 11:42 PM
88s10Blazer
11-23-2006 03:33 PM
