door lock relays
Interesting, I'm having that same problem and been searching what is the cause, I now have a better idea on what to check
having a 2dr and not being able to open up the back to get stuff in and out sucks!
I imagine, I was having that problem too, I did find the fuse blown now my power locks work with the switch but still have no power mirror working
Gojorg:
So now what you want to do is pull the switch panel and look for overheated/broken mirror switch. That or a shorted mirror motor is what probably blew it. If neither works, likely the switch
pettyfog:
it was the 3amp fuse blown under the hood, luckily there was a spare there so now its all working fine again. Note to self dont press and hold the hatch unlock switch. thanks for the help!
Gojorg:
i had the same problem with my power mirrors not working so i pulled the swtich apart and found a bunch of green gold in it so i cleaned it up the best i could, put it back togather and was able to move the mirrors but only in one direction. so i got a new switch from the dealer for $70 and all works fine now.
Gojorg:
I thought it was the switch because about a month ago someone ripped the driver side mirror while parked and when I replaced it I noticed that I had no power mirrors while reading around here I read about the power locks too and went out and checked and that wasn't working either (I know, who knows how long it have been like that but since I'm the only one that drives it I don't have to constantly adjust the mirrors and since I use the alarm to open and close it never used the switch for the locks) I just replaced the switches because my power windows was acting funny and found a set of switches with woodgrain trim off a bravada now no issues with the power windows, I will put my old power mirror switch and check if it works tomorrow
cherryred4x4
01-13-2007 09:25 PM
2FAST4U
08-12-2005 02:30 PM
