Door Locks
Old Oct 10, 2012 | 10:53 PM
Mitakid's Avatar
Mitakid is on a distinguished road
Default Door Locks
When I use the key to unlock car [95 LT], none of the other door locks respond, have tried fuses but no help, anybody got any idea.
Old Oct 10, 2012 | 11:48 PM
richphotos's Avatar
we need more info. What do you mean exactly, are you talking about the keyless entry, or just putting the key in the door and unlocking it?
Old Oct 11, 2012 | 10:11 PM
Mitakid's Avatar
Default Door Locks
When I use the key, only the drivers door unlocks the rest remain locked even the rear window. My keyless entry developed a short circuit and was too expensive to replace.
Old Oct 12, 2012 | 07:03 AM
richphotos's Avatar
The rest should remain locked I believe until you push the unlock button.
Old Oct 12, 2012 | 08:41 AM
rriddle3's Avatar
Correct. A key only operates the lock in which it is used.
Old Oct 12, 2012 | 08:26 PM
Interesting, on my 98 LS, when I use the key in the driver door, it locks/unlocks the hatch as well. Same goes with the hatch lock, (locks/unlocks the driver door). There's a switch in the outside driver door handle that operates the power lock relays.
Old Oct 14, 2012 | 08:29 PM
Mitakid's Avatar
Sounds like i am a little confused but when i use the key to open driver's side door when i hit unlock switch it does not open other locks, when I try to open rear door with key it does nothing, normally it opens all locks.
ussexplorer
May 11, 2011 09:04 PM
truck608
Oct 14, 2007 11:56 PM
Craig Austin
Nov 14, 2006 01:20 PM
Craig Austin
Oct 22, 2006 06:48 PM
Bojib
Jan 27, 2006 01:29 AM
