Downshifting into 3 on hills
Hey guys. Is it true that it is better for the transmission if I downshift into 3 (out of overdrive) when driving up hills? There are alot of steep hills in this town and I always seem to get more power when I put the shifter into 3 just before a steep hill. Am I doing damage or is it safer for the trans to be driving in 3 on hills? I notice that when I am off the hill on level ground that it feels like there is some "resistance" as if I was towing something or having both rear tires almost flat. Thanks.
Its been covered quite a bit in the past. The only reason to down shift is if the transmission is continually hunting between 3rd and 4th. The more shifting that is going on, the more heat is generated and the more wear/tear there is on the fluid & clutches.
If you feel more peace of mind by running it in 3rd, go right ahead. You won't be damaging anything, but if you are doing so unnecessarily, you will be using more fuel.
Great thanks. There are so many hills and idling where I am. I only get about 9-11 mpg in town. I can get 18-20 highway at 65mph. Fuel consumption is no factor when it comes to keeping the transmission safe.
At least that is what I thought it said in the manual. I tried 2 from a stop a couple times. Felt like it had no power, but when I was in 1/3/D it would start normally. Even when I shift into 3 from 2, it would downshift into 1 properly and I would have my power back.
I would think that you could find someone that does tuning and they could modify your shift points to better suit that area you live in. Maybe that it stays in 3rd gear until a higher speed (say you are on these hills and the speed limit is 45, you could have it stay in 3rd until close to 55 instead).
Yah staying in 3rd is fine OD is ur low power highway gear, I wouldn't use 2nd though you are gonna be turning alot of rpm and heating up the tranny quick. And the 2 on the shifter should do 1st and 2nd like the poster thought
I don't use 2nd anyway unless I am going down a steep hill and need the additional braking power to keep it under control, but I don't do that unless I am moving under 20 mph, 25 max, then I go to 3 and use more braking force. I only go to 1 if I am going down or up a REALLY STEEP hill at 5 mph or less or if I am pulling something (like in the 2 instances when I had to pull another vehicle 20 feet out of mud and snow. Didn't even spin the tires, no matter if it was in 2HI or 4LO.) or if I am in 4HI or 4LO in deep snow or offroad so I don't have to worry about the trans upshifting and causing heat buildup at slower speeds where the trans cooler is useless.
I don't know if programming it would be a good idea since alot of my miles are actually on interstate highways (most of which are between college and home), but I go to college in a small town and I live in another small town. Both towns have alot of hills.
Also my trans cooler is mounted with the fittings pointed down (upside down?) and the hoses are routed behind the bumper. Is that correct? Is it cooling properly like that or is it useless? Thanks
zstudna
Mar 30, 2014 09:26 AM
Silver00LT
Aug 10, 2013 06:43 AM
