-   -   Driver Door Sag... (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/driver-door-sag-87021/)
donny612 Aug 28, 2014 04:34 PM
Driver Door Sag...
I have a 2001 Trailblazer which has worn door hinge bushings. So I figured hey, no biggie, I'll just replace them. So I got the old ones out and put in the new bushings and hinge pins and the door drop was much improved but not back to normal. As a few weeks passed the door drop after opening the door worsened. So i said hey, replace the bushings again as I could see they were mostly broken. This time I did a better job of cleaning out the holes and replaced them again. Well guess what...they're broken again. Is there anywhere to get those bushings with some quality and not these stupid pot metal bushings???? Some good steel bushings, I'm sure, would take care of the problem but all I can find are the pot metal ones. I haven't checked with the dealer for a replacement Chevrolet part, but that may be my next stop. Any thoughts would be most appreciated!!
Thanks,
hdwingding Sep 2, 2014 10:24 AM
i got what seems to be a decent set from "rock auto" make sure the hinge plates are not severely oblonged. if steel is really needed, a look or call to "Mc Master Carr" should find you what you need. i would aquire a new pin set as to be able to measure the inferior bushings to equate them to steel.
akaSPITTYBAYS Sep 2, 2014 11:42 AM
think mine were dorman and seem fine
altoncustomtech Sep 2, 2014 03:32 PM
I have the same issue, the problem is that the hole in the hinge is too far oblonged and the weight of the door is simply breaking the bushing.
The only cheap and easy hope for repairing it is to take a welder and fill in the oblong side of the hole and grind/drill the hole back to the proper size. A person could also use a torch and braze the hole back to shape for grinding/drilling but I would think the welder would be the better option.
A more expensive option, but not nearly as expensive or troublesome as replacing the entire hinge, would be to order and install one of THESE kits. The premise behind the kit is to drill out the oblong hole to get a nice oversize one then use oversize bushings. The kits also have the ONLY greaseable hinge pins for these trucks I've found on the market.
I'm considering the expensive kit because after spending the money on a new engine and transmission I plan on keeping this truck for a LONG time.
Captain Hook Sep 2, 2014 08:52 PM
Might try these first. They are available .010 and .020 oversize: Catalog :: Total Automotive Hinge Kit Solutions
Also, you can't just beat the bushings in with a hammer. Either the bushing will shatter, or the hinge ear will bend, or both. They must be pressed in.
akaSPITTYBAYS Sep 3, 2014 05:25 PM
+++^^^ C-Clamp
Captain Hook Sep 3, 2014 09:09 PM
Yup, that works. C clamp or a bolt and nut with a socket on the underside. Make sure the bushing is straight, and pull her in.
akaSPITTYBAYS Sep 4, 2014 12:03 PM
Chuck the nut and bolt is genius!
Love it. I can think about ten things to play with that idea right now.
donny612 Sep 4, 2014 12:20 PM
Oversize?
Is it just the o.d. that's oversize or is the entire bushing larger? Do I need oversize hinge pins as well or is the i.d. the standard size? Thanks!!
newguy Sep 4, 2014 12:45 PM
Hows the body mount under the front of the door?
