Driver's power seat rocks back and forth!
Old Sep 13, 2007 | 04:00 PM
soundguy's Avatar
soundguy is an unknown quantity at this point
Default Driver's power seat rocks back and forth!
did a search to no avail. My drivers seat has the six-way power adjustable lower cushion and the whole seat rocks back and forth slightly when I accell and brake - annoying! I checked it out and the play seems to be located in the motor/actuator that adjusts the front portion of thetilt of the bottom cushion (frontmost up/down switch).
Anyone had to doa fix on this before? Thanks! -Mike
Old Sep 20, 2007 | 07:22 AM
soundguy's Avatar
Default RE: Driver's power seat rocks back and forth!
bump, play is in the motor/actuator assy. nearest to the door jamb under the seat. If I replace this motor assy. will that fix it? anyone?...anyone?... Bueler?... Bueler?...
Old Sep 20, 2007 | 08:05 AM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
If you are sure that is where the 'play' is coming from well yes replacing it should solve your problem , just go to the wreckers and and get one there ....
Zed
Old Sep 20, 2007 | 09:24 AM
95_4door's Avatar
95_4door is an unknown quantity at this point
I have the same problem. It just doesn't bother me enough to go buy a new assembly.
Old Sep 20, 2007 | 03:23 PM
88blackzcand95blazer's Avatar
88blackzcand95blazer is an unknown quantity at this point
same prob here....annoying!
er0ck273
Sep 1, 2013 11:45 AM
kickme005
Sep 6, 2010 06:03 PM
jmaynard
Aug 28, 2010 03:56 PM
98blazergal
Nov 5, 2006 01:49 AM
beilharzc
Mar 12, 2006 01:50 AM
