Driver's seat adjustment.
Hi everybody!
I have a problem - doesn't work adjustment of driver's seat.
I would very appreciate if somebody could give me as detailed as possible instructions how to fix it.
Thank you in advance.
Blazer S-10, 1995, 4,3L
RE: Driver's seat adjustment.
I think all of our driver's seat recliners don't work.....I thought that was just part of a Chevy Blazer. lol
Are you talking about the recline handle or the lever underneath to slide it back and forth along the track?
I mean the lever underneath to slide it back and forth.
is itstuck or just moving freely and not moving your seat?
It does not move at all, whatever button you hit. [/align]
Unless you have power seats, it shouldn't be a button. It's a metal bar which you need to pull up on to disengage the lock and then slide the seat with the bar still pulled. The bar should be located flush with the front of the seat. If you pull up on the lever and the seat is sliding rough, try a shot of WD-40 along the track to lubricate things.
It is power seat [/align]
In that case, what adjustment does not work? And how many options do you have for adjustment (recline, forward/back, fore/aft tilt)?
njk53
11-16-2010 09:39 AM
