Driver seat adjustment problems
Old Mar 2, 2009 | 11:05 AM
murraymelm's Avatar
murraymelm is an unknown quantity at this point
Default Driver seat adjustment problems
Help. Whenever the position of the driver's seat is changed, it won't hold. And often it is quite dangerous as the driver's seat goes all the way back leaving my feet off the pedals. It happens when I accelerate or stop. But once I get the seat back on the "notch" then it is fine until the seat has to be adjusted again.
Old Mar 2, 2009 | 12:15 PM
Default RE: Driver seat adjustment problems
Sounds like either the latch is not properly seating in any other position or that things are just worn out underneath. If you push down on the adjustment arm when you get close, can you make it latch in?
Old Mar 15, 2009 | 12:02 AM
91chevyblaze's Avatar
91chevyblaze is an unknown quantity at this point
try take the cover off the side that covers the mechanics of it and lube it up a little bit using 3 in 1 oil it happened to me and thats what i did and now it works just fine
njk53
Nov 16, 2010 09:39 AM
kickme005
Sep 6, 2010 06:03 PM
Smoked
Mar 17, 2008 01:52 PM
Nokus
Jan 2, 2008 11:40 AM
kaejr
May 22, 2007 01:01 PM
