drivers side power window :/
Old Oct 30, 2010 | 05:17 PM
Sturg's Avatar
Sturg is on a distinguished road
Default drivers side power window :/
Ok so I got the door panel and water shield and all that good stuff off. Then I drilled out the rivits and started pulling on the motor, couldn't get it out and ran out of time and had to leave. So I get on here last night and find out that the spring could cut my fingers/hand off. So basically I know now that the regulator has to come out but how do you disconnect the arm from the window sash thing? I'm confused and now scared to do this seeing as how I have a ticking time bomb in my door lol.
Old Oct 30, 2010 | 07:16 PM
That is unfortunate... Can you drill a hole through the regulator now to lock it into place?
As far as how to get it out of the channel on the bottom of the window, you have to move the regulator front to back to get the rollers into the openings either at the front/back of the channel or in the middle.
Old Oct 30, 2010 | 11:35 PM
Sturg's Avatar
I don't know. What do I drill through... I know you drill through the regulator but to hold it in place i need to drill through like the bottom of the arm right?
Old Oct 31, 2010 | 08:54 AM
You have to drill through two portions of the regulator that either normally move opposite each other (the two arms) or from one arm to a stationary portion of the regulator frame. This will lock the regulator in position so that you can remove the motor.
Old Oct 31, 2010 | 12:21 PM
Sturg's Avatar
Ok thanks I will let you know how it goes.... Hopefully I keep all my fingers haha
Fast Rider
Dec 22, 2014 08:44 AM
upmaine
Jul 9, 2012 12:31 PM
Wexinlo
Apr 6, 2011 11:35 PM
bagged01blazer
Aug 31, 2009 10:24 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
