Drivers side tire wear on the inside
Yup my drivers side inside is worn, and its just that tire i can tell they have been regularly rotated and all. that's kinda whats got me worried its about as worn as it can get too :/ i was thinkin a ball joint has took a ****? any ideas? 99 blazer 4x4
Jack it up, with the jack under the lower control arm to take the tension off the suspension, once the tire is an inch or 2 off the ground, grab the bottom, and top of the tire, (6 and 12 oclock) if the tire wiggles at all, its the upper ball joint, to test the lower, put a bar underneath the tire, and have someone lift up on the bar to lift the tire up and check the lower balljoint for movement.
Exactly what I did!
upmaine
Jul 9, 2012 12:31 PM
Wexinlo
Apr 6, 2011 11:35 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
fruccoman
Feb 15, 2006 07:08 PM
