DRL Module
Old Nov 16, 2008 | 12:44 PM
Vortec4300's Avatar
Vortec4300 is an unknown quantity at this point
Default DRL Module
Does anyone know the location of the DRL module on an 04 Blazer? Still trying to hook up driving lights to come on with high beams only. Thinking I can tap into high beam indicator lead coming from DRL module. Thanks for any info.
Old Nov 16, 2008 | 11:08 PM
WolfPack's Avatar
Default RE: DRL Module
You cant tap the switch power into the high beam wire itself? Then you only have power to the switch through the relay when the highs are on?
Old Nov 17, 2008 | 04:27 PM
Vortec4300's Avatar
Tried that. Driving lights would come on with daytime running lights.
Old Nov 17, 2008 | 04:43 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
Also, are the DRL supposed to be on during all daytime driving? I had to have my cousin follow me today, in my Jimmy, and I noticed that they didn't come on, until he'd driven for about a 1/2 mile. They're not supposed to do that, right? If so, how would I fix it?
Old Nov 17, 2008 | 05:16 PM
Vortec4300's Avatar
No, that doesn't sound right. They should come on when you put it in drive and release the parking brake. Wouldn't have a clue how to fix that. It was so much simpler when you pulled a **** on the dash to turn your lights on and had a dimmer switch on the floor. Guess I'm showing my age.
Old Nov 17, 2008 | 05:51 PM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
So I take it the method I had suggested in the other thread won't work? I can see if it won't though.
Old Nov 17, 2008 | 06:56 PM
Vortec4300's Avatar
Haven't tried it yet. Still trying to get more info on that type of relay.
Old May 16, 2009 | 08:08 PM
ChevyBlazerLS99's Avatar
ChevyBlazerLS99 is on a distinguished road
Default Drl
i have a question. I have a 1999 Blazer Ls 4dr and i dont want the DRL ( Day Time Running Lights ) On while im driving. I want to make it so that i can control my lights manually. What is the best way to make it so i can control them manually. Any comments/ or tips will help, thanks
Old May 16, 2009 | 08:29 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if you do a lil searching i beleive theres a right up on how to disable ur DRLs
Old May 16, 2009 | 10:15 PM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Smile
Here is an excellent writeup on how to disable the DRL's on our vehicles.
http://www.s10forum.com/forum/f62/ah...-how-tos-34645
Hope this is what your looking for.
