dtc codes? what to do
Old Jan 18, 2010 | 07:11 PM
blazinnzr2's Avatar
blazinnzr2 is on a distinguished road
Talking dtc codes? what to do
i have a hypertech power programmer and i checked the dtc codes and looked them up in the chilton manual the first one is p0101 maf error i changed the maf and it still comes up what else could it be? than there is the p0128 code it is not listed in the book what is this one about. also i have a p0155 ho2s heater preformance bank 2 sensor 1 what is this one and i also have a p0300 random missfire any ideas thanks guys this site has been alot of help thus far helping me sort out all the stuff that is wrong with my baby
blaizinnzr2
Old Jan 18, 2010 | 09:19 PM
wolfcat812's Avatar
wolfcat812 is on a distinguished road
I think the p0128 has something to do with the cooling system the random missfire could be alot of things like fuelpressure reg,dist cap,wires,plugs etc well Ihope this points you in the right direction good luck.
Old Jan 18, 2010 | 10:48 PM
blazerboyz's Avatar
Banned
blazerboyz is on a distinguished road
Allright, let me get this stright! YOU HAVE A POWER PROGRAMER AND YOUR GETTING ALL THESE CODES!!!!! Why dont you take the programer off, drive the truck around and see if your code's still exisit. PLUS it is a proven fact that if you mess with something it's gonna break eventually, and this include's ECU'S, PCM'S, and TCM'S......Take a second and think about it you altered a COMPUTER and now you have issue's Hummmm wonder what the problem is?
Old Jan 19, 2010 | 06:27 AM
rriddle3's Avatar
Old Jan 19, 2010 | 06:30 AM
If there is one thing I can impress upon everyone that is experiencing any DTC it would be this... Diagnose the problem. Do not just throw parts at it.
P0101 - Mass Air Flow System Performance
P0128 - Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
P030x - Random/Multiple Cylinder Misfire Detected
I do not have the time to pull the P0128 code sheets together, but you should check the engine temperature. This is likely an issue with the thermostat.
Old Jan 19, 2010 | 03:08 PM
blazinnzr2's Avatar
Default dtc's
i had these codes come up before i put the programmer on the truck so i dont think thats the cause however i did put an aftermarket air intake and thermostat on my truck is possible they may be to blame for the codes?
thanks to all who responded to my post your links were a big help i will take a look n see what i can find that is wrong before i start replacing parts and i will keep u posted.
thanks guys
blazinnzr2
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
Ron9919
Oct 30, 2007 10:16 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
