DTC Codes.......
Old Oct 22, 2007 | 02:48 PM
Ron9919's Avatar
Ron9919 is an unknown quantity at this point
Default DTC Codes.......
Can Someone give me a complete list of all the DTC codes for the 1998 Blazer 4WD V6.......
Old Oct 22, 2007 | 03:08 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: DTC Codes.......
I'll try to get them at school tomorrow. We have acess to AllData Pro.
Old Oct 22, 2007 | 03:34 PM
Ron9919's Avatar
Awesome dude.......I really dont car about getting the body codes just the P codes in the ECM...
Old Oct 22, 2007 | 03:43 PM
EuroGoldLS's Avatar
Nevermind that. I just found them.
Get ready. There are all the GM P codes.
[size=2]P0102 Mass Air Flow circuit Low Input.
P0103 Mass Air Flow circuit High Input.
P0106 EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range.
P0107 EGR/BARO Signal circuit is Less Than Self-Test minimum.
P0108 EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range.
P0112 Intake Air Temperature circuit Low Input.
P0113 Intake Air Temperature circuit High Input.
P0117 Engine Coolant Temperature circuit Low Input.
P0118 Engine Coolant Temperature circuit High Input.
P0121 In-Range Operating Throttle Position Sensor circuit failure.
P0122 Throttle Position Sensor circuit Low Input.
P0123 Throttle Position Sensor circuit High Input.
P0125 Insufficient Coolant Temperature to enter Closed Loop.
P0126 Insufficient Coolant Temperature for Stable Operation.
P0131 Upstream Heated Oxygen Sensor circuit out of range - Bank No. 1.
P0132 Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1.
P0133 Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 1.
P0135 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0136 Downstream Heated Oxygen Sensor circuit fault - Bank No. 1.
P0138 Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1.
P0140 Downstream Heated Oxygen Sensor circuit Faulty - Bank No. 1.
P0141 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0151 Upstream Heated Oxygen Sensor circuit out of range - Bank No. 2.
P0152 Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2.
P0153 Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 2.
P0155 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0156 Downstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0158 Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2.
P0160 Downstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0161 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0171 System Too Lean - Bank No. 1.
P0172 System Too Rich - Bank No. 1.
P0174 System Too Lean - Bank No. 2.
P0175 System Too Rich - Bank No. 2.
P0176 Flexible Fuel Sensor.
P0180 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0181 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0182 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0183 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0187 Engine Fuel Temperature Sensor circuit.
P0188 Engine Fuel Temperature Sensor circuit.
P0190 FRP Sensor Signal Low.
P0191 Engine Fuel Temperature Sensor circuit.
P0192 Engine Fuel Temperature Sensor circuit .
P0193 Engine Fuel Temperature Sensor circuit.
P0222 Throttle Position Sensor B circuit Input Low.
P0223 Throttle Position Sensor B circuit Input High.
P0230 Fuel Pump Primary circuit fault.
P0231 Fuel Pump Secondary circuit Low.
P0232 Fuel Pump Secondary circuit High.
P0300 Random Misfire Detected.
P0301 Misfire Detected - Cylinders 1-10.
P0302 Misfire Detected - Cylinders 1-10.
P0303 Misfire Detected - Cylinders 1-10.
P0304 Misfire Detected - Cylinders 1-10.
P0305 Misfire Detected - Cylinders 1-10.
P0306 Misfire Detected - Cylinders 1-10.
P0307 Misfire Detected - Cylinders 1-10.
P0308 Misfire Detected - Cylinders 1-10.
P0309 Misfire Detected - Cylinders 1-10.
P0310 Misfire Detected - Cylinders 1-10.
P0320 Ignition Engine Speed (PIP) Input circuit fault.
P0325 A Spark Knock Occurred - Sensor Circuitry did not respond.
P0326 Spark Knock has not been sensed.
P0330 A Spark Knock occurred - Sensor Circuitry did not respond.
P0331 Spark Knock has not been sensed.
P0340 Camshaft Position Sensor circuit fault.
P0350 Ignition Coil Primary circuit fault.
P0351 Ignition Coil A Primary circuit fault.
P0352 Ignition Coil
Old Oct 22, 2007 | 09:28 PM
Please be aware that some of these will not apply as well as some of them being different depending on the specific GM application.
For a reference, I use OBDii.com just click on codes and refresh the screen. Then select the make and type in the specific code.
Old Oct 22, 2007 | 09:37 PM
EuroGoldLS's Avatar
True enough. Some GM applications will have different codes depending on the what it was equipped with.
Old Oct 30, 2007 | 08:26 AM
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
This was the 1st code my 2001 blazer threw out
P0440 Evaporative Emission Purge Control Solenoid Damaged.
This is the 2nd code my 2001 blazer threw out (I have gotten this code 4 or 5 times so far)
P0446 Evaporative Emission Control System Vent Control malfunction.
1. I replaced the gas cap. Got it at Autozone. Worked for 2 weeks then "Check Engine Light" Came back on
2. I also replaced the Purge Valve. Worked for 1 day. then "Check Engine Light" Came back on. I got the code removed from the computer. It was this code again. What could be causing the "Check Engine Light"to keep itcomingback on?
Kevin From Shelton (Quinnman105)
Old Oct 30, 2007 | 10:16 AM
Kevin, please create your own topic on this problem.
abadinalbany
Apr 16, 2011 11:31 AM
blazinnzr2
Jan 19, 2010 03:08 PM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
