Ebcm c0065
Old Feb 22, 2012 | 07:26 PM
gturb03's Avatar
gturb03 is on a distinguished road
Default Ebcm c0065
I have posted this on the GMC Jimmy forum and have not got an answer of any kind. So I'm going to try here.
My son has a 1997 Jimmy and the Anit-lock brake light comes on when he starts driving. If he turns the truck off the light will go out and back on when he starts driving again. The code that comes up is C0065 Pump Motor Relay Circuit Open. Was told that the EBCM needs replaced. We are having a problem finding one. Would a salvage part be the way to go? Or where to get one? I was looking at the ABS pump and it looks like it's under the pump motor or am I looking at the wrong part?
Thanks for any help.
Jerry
Old Feb 22, 2012 | 08:39 PM
pettyfog's Avatar
C0065 correlates to 'left front sol..' according to a google search
Here's an index
https://blazerforum.com/forum/tech-a...agnosis-26408/
Are you sure it isnt C0265?
https://blazerforum.com/forum/diagno...plained-35164/
Old Feb 22, 2012 | 09:44 PM
gturb03's Avatar
The print out that was givin to me said C0065: pump motor relay circuit open.
Old Feb 22, 2012 | 10:00 PM
pettyfog's Avatar
Hmmm.. Read for yourself
http://m.modernhemi.com/forums/showthread.php?t=625158
I dont think GM would use same codes for two different things.
Maybe look at wiring for both.
Old Feb 22, 2012 | 10:33 PM
C0065 is a fault in the left front #2 solenoid circuit, which is located inside the EBCM. If the flow chart directs you to replace the EBCM, a Google search will reveal several companies that rebuild them.
Old Mar 3, 2012 | 08:43 PM
gturb03's Avatar
Ok I have searched and having a problem finding someone that rebuilds the 1997 model EBCM or I'm not looking in the right places. I can find allot of them that rebuild 1999-200? Something.
Old Mar 4, 2012 | 06:30 PM
gturb03's Avatar
I found a used one on eBay does anything need to be done if I get a used one.
Old Mar 4, 2012 | 07:17 PM
Other than install it, nope Plug 'n play.
webxfx
Jan 13, 2013 05:51 PM
rods55s
Dec 9, 2012 11:43 AM
Kaffeene
Feb 29, 2012 07:29 PM
Kai
May 8, 2011 08:01 PM
Slnt Dnky
Jan 19, 2009 01:58 PM
