Where is the EBCM on a 98?
Old Feb 29, 2012 | 06:49 PM
Kaffeene's Avatar
Kaffeene is an unknown quantity at this point
Default Where is the EBCM on a 98?
Where is the EBCM (electronic brake control module) located on a 98? I've been getting trouble code CO265 for awhile now and would like to check the ground and other connections.
I've actually have 4 codes: CO281, CO223, CO221 and CO265. The ABS light and ABS will kick in only after driving for a couple hundred feet and then the ABS light will stay on and the ABS will not kick in until the ignition is cycled again. The light started to come on last year a few weeks after I replaced both wheel bearings, which also contain the speed sensors and I have checked the connection. CO223 & 221 are related to the right front speed sensor, I'm not sure if this will also trigger the other 2 codes. If anyone has some experience with this problem or the EBCM your input is really appreciated, thanks.
Old Feb 29, 2012 | 07:29 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default Brake Control Module
This is located in the engine bay on the drivers side. The module is in the silver colored box with all the brake fluid lines attached.
webxfx
Jan 13, 2013 05:51 PM
rods55s
Dec 9, 2012 11:43 AM
gturb03
Mar 4, 2012 07:17 PM
Kai
May 8, 2011 08:01 PM
Slnt Dnky
Jan 19, 2009 01:58 PM
