Edelbrok Manifold
Old May 5, 2008 | 04:16 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
Default Edelbrok Manifold
Will this do anything that is worth buying? Does anyone have one?
http://store.summitracing.com/partde...p;autoview=sku
*Combining Consecutive Posts*
Instructions says it will not fit egr systems. Can this be bypassed?
*EDIT by swartlkk* - Please use the EDIT feature to add additional information to your post if another member has yet to reply.
Old May 5, 2008 | 04:23 PM
ivannj's Avatar
Default RE: Edelbrok Manifold
Old May 5, 2008 | 04:31 PM
rriddle3's Avatar
Edelbrock says:
EGR SYSTEM:
This manifold will not accept stock EGR (exhaust gas recirculation) equipment. Not legal on pollution controlled
motor vehicles.
MANIFOLD
: This manifold will not accept any O.E.M. carburetor systems. We suggest you use the carburetor listed in
the carburetor recommendations. This manifold was designed for street rod, off-road and marine applications.
If you're planning on using the truck on the street, the answer is pretty clear - NO. This is designed for off-road and track use only with suitable engine set-up. BTW, you've been gone a long time.
Old May 5, 2008 | 05:03 PM
ivannj's Avatar
Yeah been gone for a while but been driving same truck! So Basically It will not fit? What does it need to fit?
Old May 5, 2008 | 05:21 PM
rriddle3's Avatar
After going through their catalog, I just don't see anything that is designed for your engine to be used on the street.
Old May 5, 2008 | 05:44 PM
ivannj's Avatar
Just becuase it not for street does not mean it can't be installed? I likebreaking the law. Just kidding.
Old May 5, 2008 | 07:16 PM
95LS's Avatar
95LS is an unknown quantity at this point
for that to work on your truck youre going to have to get a EGR block off plate to start with. i dont know how much computer/electrical work youll have to do. you will also need to convert to a carb insted of fuel injection.
Old May 5, 2008 | 09:28 PM
That manifold does not even have EGR provisions. Will it bolt on. Sure.
Getting it working with the rest of your truck... Good luck. What are you hoping to gain by using this?
Many people use this intake and modify it with fuel injector bungs and a throttle body for running turbo applications. Unless you are going this route, I wouldn't bother messing around with it.
BTW, Welcome back!
dunontme
Nov 17, 2009 11:04 PM
kiliwizz
Jun 8, 2006 05:54 PM
rpishoman
Headers, Intake, & Exhaust
Dec 3, 2005 01:58 AM
blazerdan
Jul 14, 2005 12:51 AM
00blazer
Mar 30, 2005 12:24 PM
