EGR valve
Old Apr 1, 2011 | 01:23 PM
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
Default EGR valve
OK i have a 96 blazer with very poor gas mileage.
and a stutter (occasionally).
I checked the Egr valge with this diagnostics.
Here is the site so you know where I got my info.
XXXX://easyautodiagnostics.com/gm_egr_test/gm_egr_valve_1.php
for test one I got .89
If your Multimeter displayed .6 to .9 Volts DC I goto step 6
There I cleaned up and carbon with carburetor cleaner spray, now it looks carbon free..
there I go to test 5 and that gives me a reading of 6.47, EGR Valve's Pintle fully pressed into the EGR Valve, will be about 4.5 Volts DC is what the article tells me.
Now the Pintle is free and goes smoothly..
but the voltage is 6.47 not the 4.5.. What do I make of this huge voltage difference?? Is the egr valve bad??
I installed a new gasket toe ..
Any ideas are welcomed please.
Old Apr 4, 2011 | 10:25 AM
Beckyj636's Avatar
does anyhone have ides on this egr valve? i will goto autozone this morning to see what the obd2 scanner tels me with i/m settings.
Old Apr 4, 2011 | 11:26 AM
The position return to the PCM uses the reference 5V wire for it's power source. If you are getting more than 5V on the return, then there likely is something wrong with either the 5V reference being too high (shorted to another +12V wire) or an internal fault in the EGR valve.
A full feature scan tool can be used to monitor the position return during operation to see if the indicated position matches the commanded position.
Old Apr 5, 2011 | 01:13 AM
Beckyj636's Avatar
What is meant by " you are getting more than 5V on the return"
I get the 6.47 v when EGR Valve's Pintle fully pressed into the EGR Valve
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
BlaziNator
Oct 26, 2009 03:43 PM
yzf125
16
Jun 18, 2007 02:47 PM
khalid_20879
Mar 14, 2006 04:23 AM
dobbist
Engine & Internal
May 1, 2005 04:02 AM
