Electric Park Lock
Old Dec 26, 2009 | 09:31 PM
rancher58's Avatar
rancher58 is on a distinguished road
Default Electric Park Lock
I own a 2001 Jimmy 4x4 with automatic shifter on the floor. My problem is that it will not come out of park, I searched on this forum half the night for a solution and found a mention to an electric park lock. Would this be my problem and how difficult to fix. Thanks
Old Dec 27, 2009 | 01:15 AM
RonJon's Avatar
RonJon is an unknown quantity at this point
Could be a wiring problem, could be part of your brake switch, could be the solenoid on your shifter. Check the B/U LP and BTSI fuse in the underhood fuseblock. On your shifter is two solenoids with a 3 wire connector going to them. BLK is ground, LT GRN/BLK and DRK GRN/WHT have power when you turn the key on. When you step on the brakes the DRK GRN/WHT will lose power. You can check that with a test light and check continuity on the solenoids with an ohm meter.
metalmeltr
Nov 27, 2013 01:22 AM
mychevyisntheavy
Oct 30, 2011 10:00 AM
toyblazervt
Nov 28, 2010 05:07 PM
Mooney9
Oct 7, 2009 08:23 AM
punx.inc
Dec 25, 2007 12:07 AM
