Electrical problem
Old Mar 15, 2010 | 11:01 AM
chop's Avatar
chop is on a distinguished road
Default Electrical problem
Hey
I have a problem with my blazer and i dont know where to start looking for solution.
Although the power seats work fine, when i turn the switch the seats dont produce any heat. Same thing with rearview mirrors, only the heat doesnt work.
I checked the fuse box and it seems that all fuses are ok.
Are heated seats somehow connected to heated rearview mirrors or is it just a coincidence that they stopped working at the same time?
Also the third break light doesnt work but i have noticed some moisture in it so that might be the reason.
Excuse my english, i just couldnt think of a more grammatically correct way to explain the problem.
Old Mar 15, 2010 | 04:15 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
What year is your blazer? I cant seem to find a wiring diagram for heated seats and mirrors on a 95. and as far as the third brake light goes, you should take the two screws out of the light holding it on and then dry out the light, once dry, test for 12 volts at the connector with a multimeter and the brakes applied. if you have 12 volts you need to replace the third brake light. they are pretty cheap at the junkyard and FYI Third brake lights off of suburbans and tahoes will also fit.
Old Mar 15, 2010 | 04:33 PM
chop's Avatar
Its a 95 blazer, 4x4 LT. Bought it here in croatia so its for europe market, if that makes any difference.
I tried to take off the third break light but one of the screws is spinning freely so i didnt want to mess around with it any more because im afraid i will break it.
I cant really find used parts anywhere near my area but maybe i will have more luck expanding the search for suburbans and tahoes, so thanks for that info
Old Mar 15, 2010 | 05:47 PM
Schrade's Avatar
Schrade is on a distinguished road
Your English is better than language that we hear in this country, cause you don't hear much English in America.
Mostly spanglish, ebonics, and grunts.
Old Mar 15, 2010 | 06:25 PM
jjnemoiii's Avatar
jjnemoiii is on a distinguished road
Agreed! Many people in our inner cities would not be able to understand you because your english is so good.
Old Mar 15, 2010 | 06:29 PM
jjnemoiii's Avatar
Heated seats, is this on both sides? On the passenger side, I believe you need to be sitting in the seat for it to kick on, so when a passanger gets out, the heat will turn off.
Old Mar 16, 2010 | 11:09 AM
chop's Avatar
Thanks Schrade and jjnemoiii
Heated seats are on both sides. There is a wheel shaped switch under the seat. Im not sure if i checked it while sitting on the passanger sear, will have to double check that.
JoSHN
Sep 14, 2012 04:56 PM
blazerxtreme1
Engine & Internal
Jul 7, 2006 12:46 PM
88s10Blazer
Jun 28, 2006 03:22 PM
Blazin99
Jun 12, 2006 01:15 PM
MontegoRX
Feb 15, 2006 11:30 PM
