Electronic Brake Module Motor Relay code
Old Jul 10, 2012 | 12:42 PM
SoapyTheCat's Avatar
SoapyTheCat is on a distinguished road
Default Electronic Brake Module Motor Relay code
Wondering if anyone has any insight, or if they have had any of the same.
2002 S10 Blazer 4X4, 4.3 has the ABS and Ebrake light comes on at random times and stays on till I shut off. Had all the pads, rotors, calips, and master changed out just recent for an overhaul, and the light is still popping on. The code came back as a Electronic Brake Module Motor Relay, or something of the sort motor module/module motor....
Where is the location of the Relay? and anyone had any experience with a reman module?
Would a wheel speed sensor trigger that same code or would it create a different reading? Not sure which code number it came up with, but remember the EBMM relay was the only thing it read. Everyting in the cab fuse box, and under hood fuse block were good, and the other relays listed within that box. Not sure if the ABS relay is in a different location?
Talyn
Apr 5, 2011 02:52 PM
Brian123456789
Dec 24, 2010 03:55 PM
Brian123456789
Dec 24, 2010 03:48 PM
marc.doucette
Dec 15, 2006 05:35 PM
wormburnr
Nov 4, 2006 03:47 PM
