emergency brake handle
Old May 2, 2010 | 08:21 AM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Default emergency brake handle
got the bottom of the dash( under the wheel) mostly off. the emergency brake handle won't allow me to remove the final step.
i must say there isn't to much room to get in there and make a hole thru the firewall to hookup some toggle switches.
any input ???????????????????????????????
Old May 2, 2010 | 10:58 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
There should be a wire, like whats on the throttle body, that you can disconect and it will come right off.
Old May 2, 2010 | 11:20 AM
Default handle
i see the linkage on the inside of the plastic dash. but i don't know how to separate it from the handle' i don't want to pull hard on the handle and break it. i thought there might be a screw that holds it in place but there is not one.
Old May 2, 2010 | 11:34 AM
I just went and looked at mine. Removing the wire is very simple. Take one finger and pull the metal lever towards you. Use the other hand and push up(towards the roof of the truck) on the wire. It should pop right out.
If you can't figure out what I'm talking about, look under the dash while you pull the brake release. Se the mechanism that's moving? That's the lever you need to manually move.
Old May 2, 2010 | 02:12 PM
*Moving to 2nd Gen Tech* Please read the descriptions of the sections available and choose the proper section for your question. General Chat is NOT for technical questions.
Old May 2, 2010 | 03:41 PM
Default brake handle
thank you, i just can't get it off. i lifted pull twisted and that.
i am only slightly mechanically inclined.
i have the dash hanging down with the brake lever holding on.
i will bring it down to my body guy tomorrow and it will take him 2 seconds to get it off.
thanks again..................................
tomf216
Jan 28, 2010 07:37 PM
mow10man
Apr 19, 2008 09:16 PM
jdblazer
Jan 14, 2008 07:54 PM
Lckyctch
Feb 1, 2007 09:50 AM
blazer123456789
Oct 22, 2006 12:36 AM
