Emergency with my darnd fuel tank
Old 12-07-2009, 11:26 PM
ekiMMike's Avatar
ekiMMike is on a distinguished road
Exclamation Emergency with my darnd fuel tank
uhm, i broke off a..hose or a valve on the tank on my 97 4wd LS
its the one closest to the driverside seat, and im almost positive its the fuel gauge sensor or something like that. Can one of you wise chevy owner assist me in my assumtion? I need to get her street legal by wed. lol
thank you in advance!
Old 12-08-2009, 08:23 AM
There are a lot of hoses/valves on top of the tank.. You are going to have to be more specific as to its location...
What were you doing when you broke it?
Old 12-08-2009, 10:54 AM
ekiMMike's Avatar
ha, well i mean its literally ON the tank, like attached to it. i was replacing the fuel pump so i was taking the tank down, and i didnt see that hose on the front of the tank itself (looking @ it from the back of the vehicle)
Old 12-08-2009, 11:01 AM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
I think he's talking about the vent valve on the front of the tank. You either have to go to the dealer to get a new one or get one from the JY. They just twist in. Takes about 15 sec to replace it.
Old 12-08-2009, 12:07 PM
ekiMMike's Avatar
YES
Thts exactly what im talking about
is that there to show if i gas or not on my gauges right?
Old 12-08-2009, 12:31 PM
It's a vent valve that puts the gasoline vapors into the emissions system. The fuel level float is built into the fuel pump.
Old 12-08-2009, 12:34 PM
ekiMMike's Avatar
ahh, ok.
i was just wondering cause my fuel gauge is sayin im on "E" when it has at least 1/4 of the tank full...i havnt filled her up since replacing the pump...would that have anything to do with it?
Old 12-08-2009, 12:42 PM
Did you make sure you put the fuel pump in the little tab where it fits? If not the float may be stuck.
Old 12-08-2009, 12:53 PM
ekiMMike's Avatar
yessir
ill double check today cause i have a feeling ima take it out anyways lol
but thts the actual unit for the gauge right?
Old 12-08-2009, 03:33 PM
Here is the sending unit that is part of the fuel pump.
make sure you support the tank or you will do like I did and break the barbs off of the pump then you have to get another one.
Note the tab on the top of the fuel pump. The square connector is for the fuel pump and sending unit. The other one is a vacuum sensor
I hope this answers your questions
Quick Reply: Emergency with my darnd fuel tank
