Engine code:P0405
Old Sep 9, 2010 | 10:10 PM
Mange98's Avatar
Mange98 is on a distinguished road
Arrow Engine code:P0405
I know p405 means low exhaust return circuit or something like that, but I've tried just clearing it but it comes back on within 10 seconds of restarting the engine. What do I need to do to correct this problem? Also think it's causing my truck to use more gas, which really sucks.
Old Sep 9, 2010 | 10:12 PM
Have a read through this:
P0405 - Exhaust Gas Recirculation Sensor A Circuit Low
And let us know if you have any questions.
Old Sep 9, 2010 | 10:28 PM
Mange98's Avatar
That does help out some but by that sayin that, should I replace the EGR valve or what? Just check the wiring and connections?
Old Sep 9, 2010 | 10:41 PM
You could try cleaning it first:
EGR Valve Cleaning
Then you could ohm out the wiring between the valve and the PCM.
Old Sep 9, 2010 | 11:06 PM
Mange98's Avatar
Alright I try that. Thanks
I have one more question for now. If I have a dirty/bad EGR valve that would cause higher fuel consumption right? Also would explain the black build up coming out of the exhaust. Carbon build up right?
Last edited by swartlkk; Sep 10, 2010 at 06:48 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member has not responded prior to waiting 24 hours.
Old Sep 12, 2010 | 10:28 PM
Mange98's Avatar
I cleaned it out yesterday and it worked great. I cleared te code and never came back on, so that was good. Plus the motor sounds a little bit better. Thanks for the help.
djboyzs
Oct 14, 2013 07:14 PM
92s10Blzr
Dec 7, 2009 03:12 PM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
