noisy rear end
Old Sep 12, 2010 | 06:39 PM
redheadblazer's Avatar
redheadblazer is on a distinguished road
Default noisy rear end
what do i have to look for to find out if one rear end is compatible with another rear end? I want to replace the rear end in my 97 blazer because it has a bad vibration. How do i find out the gear ratio and how do i find out if it is a gu6 rear end?
Old Sep 13, 2010 | 12:20 AM
4x4blazerguy's Avatar
First are you sure it is a rear end? Have you checked the U-Joints? Chevy's in general don't go through rear ends unless they are run out of oil. Vibration sounds like a U-Joint to me. Maybe a axle bearing. But they are way cheaper to fix than replace the rear end.
The most accurate way to find gear ratio is to count the teeth on the ring & pinion divide the teeth on the pinion by the teeth on the ring gear. I believe if no one has changed them the codes are in the glove box.
brino1
Feb 25, 2011 08:05 PM
chevyman30571
Feb 26, 2008 06:32 PM
Raider Fish
Jan 17, 2008 02:38 PM
blazermanxx
Jul 21, 2007 04:08 AM
*TLR*
Apr 23, 2006 04:41 PM
