engine keeps dying
Old Feb 25, 2006 | 09:51 PM
squirrel's Avatar
squirrel is an unknown quantity at this point
Default engine keeps dying
My 2000 blazer has a new fuel pump and new hardware, i changed the plugs and wires .changed the air filter.put high octane gas in it.put fuel injector cleaner in it. changed the oil. double checked the battery and connections. and it will sputter at random and die out. when this happens i get NO check engine light ,sometimes i do but its rare. my voltage gage on the dash board shows everything looks normal, my engine oil pressure looks normal.someone told me it could be my e.g.r valve. one last thing, for some odd reason it take forever for the heat to warm up.i usually freeze before i get where i'm going, i checked the fluid resivour and keep it full with the proper mixture...as far as the e.g.r. valve...i have no clue what that is or what it does or where to look for it. any help at all would be great , thank you for you time.
Old Feb 26, 2006 | 05:46 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
Default RE: engine keeps dying
It has to primed since it has a new fuel pump. TURN ON SWITCh like 20 times and then turn on. GL
Old Feb 26, 2006 | 08:24 PM
You could also turn the key on and vent the fuel line at the fuel pressure test port until fuel spurts out. Wrap a rag around a small screwdriver and press down on the shrader valve while someone else turns the key to the 'RUN' position. Both this method and the one mentioned above will net the same results.
blazerboy53
Aug 12, 2015 07:53 PM
Mr. ButtA
Oct 22, 2010 03:42 PM
Flyboy024
14
Sep 15, 2010 10:51 PM
Big L
Mar 14, 2008 12:25 PM
Wmac
May 7, 2007 06:11 PM
