Engine leak again ??
Old Feb 14, 2025 | 05:32 AM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Angry Engine leak again ??
Hello everybody
I have engine oil leak in my 00 gmc jimmy, before few months I have replaced the oil pan gasket, timing cover gasket, rear main seal , oil pump , oil pickup tube and oil cooler adapter gasket but the problem now again engine oil leak from two different places. It leaks from the bottom middle of timing cover between oil pan gasket and timing cover and from the cap that exactly below torque convertor rear side of transmission.
I just want to know why it leaks again and what can I do now to stop the leak ?
Thank you
Old Apr 4, 2025 | 06:06 PM
daveca's Avatar
first guess, a new seal didnt seal.
The surfaces MUST be perfectly clean metal, no oil, grease or rust, and fasteners like timing cover screws *should* thread into clean threads. Gaskets and seals dont like dirty surfaces.
You replaced all the right parts but it may be a contaminated surface or a screw that has backed out. (?)
Fasteners should be instalked with low strength Loctite so they cant come loose. Old lockwashers must all be replaced.
Also a stuck PCV valve can cause increased crankcase pressure that blows oil out.
Unfortunately it might be necessary to do some of the work again, not easy on the S series.
Impact
Jan 7, 2016 09:39 AM
614blazer
Jan 9, 2012 03:32 PM
followme21
Aug 25, 2010 08:17 PM
Jason Rebellion
Jul 23, 2010 08:21 PM
MagicMan
Apr 30, 2008 12:49 PM
