Engine is LOUD on startup
Old Sep 8, 2015 | 07:46 AM
puttster's Avatar
Default Engine is LOUD on startup
In the mornings for the first two blocks my 4.3 sounds like a jet engine, then it settles down. I don't think it's the transmission because it's loud when I rev it in neutral too. Ideas?
Old Sep 8, 2015 | 08:45 AM
No false Bravada's Avatar
No false Bravada is on a distinguished road
Do you think it could be the cooling fan? Mine roars pretty loud on startup for a minute or so, then quiets down.
Old Sep 8, 2015 | 07:01 PM
puttster's Avatar
There is definitely a turbine quality to the sound. Is it the fan belt fixin to unravel?
Old Sep 8, 2015 | 07:27 PM
The fan should "roar" on a cold start up, until the fluid in the clutch warms up. If you increase engine rpm to around 2500, the fluid will warm up and the fan should quiet down. It should remain quiet unless the engine begins to overheat, then it should roar again in an attempt to cool the engine.
Old Sep 8, 2015 | 09:11 PM
No, the belt doesn't unravel, per se, it breaks when it fails. It almost always picks the most inopportune time to do it, as well. What I did when I got the Bravada was got a brand new belt and put on, and kept the old one in the cargo area. If and when the new belt decides to break, I've already got another one I can use until I get to an AutoZone.
But yes, the sound is normal on a cold start.
Old Sep 8, 2015 | 09:42 PM
puttster's Avatar
Thx for the explanation. Okay, that is one worry out of the way. This is a really good board, I've gotten some really good stuff from you guys.
Only a few more to go...
Old Sep 8, 2015 | 09:46 PM
puttster's Avatar
Just like the propane tank on my gas grill. What's with that anyway, always right while I'm cooking? Can't catch a break sometimes.
er0ck273
Jul 22, 2014 03:11 PM
chaoticdopey
75
Mar 16, 2012 12:03 AM
Cenwt15
Apr 29, 2007 04:20 AM
swartlkk
Nov 15, 2006 01:46 PM
blazinloud
Engine & Internal
Oct 17, 2006 05:39 PM
