engine miss
Old Dec 29, 2009 | 10:18 PM
harpomania's Avatar
harpomania is on a distinguished road
Default engine miss
had miss on #1, replaced bad ex valve, ground seat, 150 lbs comp now. still misses worse. replaced wires plugs cap rotor. still misses. replaced O2 sensors on passenger side, not drivers side. just discovered that one. still misses. took off upper intake hoping to find a bad spider. just a tiny bit of hose rubbing,no leaks, but the bottom of the lower intake is filthy, maybe from 151000 miles of life in minnesota. also my intake runners were black when i had the head off. both heads were black. i'm assuming the pcm was trying to take care of a lean condition when the o2 sensors were bad.like i previously posted, my daughter was driving it and it just lost #1. so now i'm down to the coil. how do i test it with a ohm meter? and what are the #s i'm looking for. Will a coil cause a miss? Please help me before i go get the "Captian" out of the cupboard!!! any advice is totally appreciated..Thanx
Old Dec 30, 2009 | 06:44 AM
*Thread Closed - Double Post* You already asked this question in your other thread which I have combined with your original thread on the subject... engine miss #1 cylinder
ussexplorer
Sep 27, 2013 03:38 PM
scott_wheels
Jan 26, 2010 05:49 PM
harpomania
Dec 27, 2009 04:42 PM
amxal
Mar 2, 2008 05:25 PM
huskerinaz
Feb 25, 2008 05:45 PM
