Engine rebuild help
Old Apr 3, 2013 | 10:08 AM
rockp2's Avatar
Originally Posted by Chevy33
A tip to help you keep track of things. Take pictures as you remove each piece. This will be helpful if you cannot remember things. When you get to removing the rod caps. What I do is I use an engraver (from harbor freight) to etch the cylinder number on the caps and the rods ( on the side that faces out. This keeps helps keep track of which cap goes on each rod and also I know that the piston is pointed in the right direction when I am building back up.
^^x2 on the pictures. I have a little digital camera that I keep in the garage and not only do I take a pic along the way, I also label tape every connection...A to A, etc.
One other thought, you might want to consider buying a re-manufactured long block. The one I bought came with a 3-year warranty. Then you don't have to worry about machining, etc. You can get a long block for about $1800.00. But it also comes with the oil pump and all the gaskets you need to put the engine back together (Note: Though it comes with LIM gaskets from Victor Reinz, you would probably want to put those aside and get the Fel-Pro LIM gaskets). May seem like a lot now...but you will be surprised how the nickles and dimes add up for a complete re-build.
Stansfield
Jul 4, 2010 06:54 AM
gmoney30
Jan 22, 2010 07:07 PM
emanpimpster
Feb 29, 2008 06:58 AM
88s10Blazer
Dec 25, 2007 09:29 PM
89Blazze
Jan 13, 2006 09:52 AM
