engine squeaking
Old Jan 10, 2010 | 08:00 PM
leeclark's Avatar
leeclark is an unknown quantity at this point
Default engine squeaking
my engine has been squeaking for about a year and a half now havnt been able to pin point it. had to remove the a/c compressor cause it locked up. the water pump has been changed as well as the harmonic balancer, alternator, and belt tensioner. anyone else have that problem? what did it turn out to be? drives me crazy and cant really tell exactly where its comeing from. maybe the fan clutch?
Old Jan 10, 2010 | 08:21 PM
awe341's Avatar
awe341 is on a distinguished road
Try some WD40 on the idler pulley bearing, If the noise quiets then replace the pully and your good. That is where the squeak on mine was coming from.
If it's not that then there is the possibility that it is the power steering pump bearing. Though that usually would be a much lower pitch.
You can always take off the belt and start manually spinning each item one at a time until you find something that either doesn't feel or sound right.
Old Jan 10, 2010 | 09:05 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
I like awe's idea of removing the belt and feeling things. See if the idlers wiggle side to side, that's how I figured out my annoying squeak was the plastic pulley on the spring loaded arm.
Old Jan 10, 2010 | 09:28 PM
argon929's Avatar
argon929 is on a distinguished road
have you changed the serpentine belt and check the aarow thing on the harmonic ballance for the timing to see if it touching the balencer check the alternator
Jdc3333
Dec 16, 2014 10:09 PM
kennysgirl
Aug 11, 2006 12:48 PM
jumper02
Jun 8, 2006 12:09 AM
blazerman
May 29, 2006 10:39 PM
tpendergraft85
Feb 17, 2006 07:10 AM
