Entertainment Center problem
Old Jul 10, 2006 | 10:11 AM
victorf's Avatar
victorf is an unknown quantity at this point
Default Entertainment Center problem
I have a 2000 blazer with a factory sound system that includes a CD player. We listen to Books-on-CD while traveling. This week, while on a trip, something went wrong with the CD drive and every time you inset a CD the drive immediately spits it back out. On the LCD display is the very informing message "err". Every once in a while the display shows the time for a fraction of a second then reverts to "err". I am able to use and tune the radio, but the error message is ALWAYS present. Has anyone here seen this? Is there anything I can do to clear the problem short of giving my GM dealer a large sum of money?
Any enlightenment will be appreciated.
Vic
Old Jul 10, 2006 | 10:16 AM
Default RE: Entertainment Center problem
Error Display (ERR):
If the laser focusing mechanism is impaired by any of the following conditions, ERR will appear on the display when the CD is loaded:
* Moisture
* Dirt
* An upside down CD
* A damaged CD
* An excessively scratched CD
The unit will switch to the radio mode and automatically eject the CD. ERR will remain on the display for 5 seconds , along with the normal display information.
If it does this with any CD, then you may want to pull the deck, remove the outside cover, and blow out the internals with some compressed CO2. Reassemble and see if that helped. If you can get a CD lense cleaner disk to stay inside and play, that would help things. It is possible that something has just gone wrong with either the focusing motor or the tray inside.
If the above doesn't help, you may just want to replace your stock deck with an aftermarket unit rather than fixing the stock peice.
Old Jul 10, 2006 | 10:54 AM
victorf's Avatar
The error message is displayed continuously with NO CD in drive. I will try a general cleaning however. Where might I find an after market replacement?
Any further enlightenment will be appreciated
Vic
Old Jul 10, 2006 | 11:24 AM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
www.crutchfield.com is usually useful, or you can go to any of your local places such as Best buy, circuit city. If your only looking for a fairly cheap replacement. I even have a nice cd player made by JVC sitting in my closet that works fine, if you want it for like $75 plus shipping. lol!
Old Apr 11, 2008 | 01:12 PM
kle717's Avatar
kle717 is an unknown quantity at this point
This just started happening to my 2000 blazer did you ever get it working?
ibyz
Apr 26, 2025 10:11 AM
matthewp
Apr 4, 2021 09:16 PM
chris015
Aug 7, 2011 12:02 AM
wmartinlsmith
Apr 3, 2008 09:00 PM
gserve
May 9, 2007 09:43 PM
