The EPA Loves the oil my truck is pouring onto the ground
Buy a new pickup screen, then set the old pump and new pump side-by-side on the bench to check the height.
mods
I replaced my old oil pump with a m155hv, changed drive shaft to a milling is55e. I was able to use the oil screen that came off old pump. Clearance has been no problem. Runs down the road with about 45 + and good pressure at low RPM. Ordered on Amazon. Pump is held on with one bolt. Separate from main bolts.
Getting the screen out of the old and into the new pump was always a bit of a challenge. Have made various tools in the past for driving the pickup/screen on....a half-round drift made from a piece of pipe was one that worked pretty darn good. I remember trying to hold the pickup/screen in position with one hand, drift-tool in another hand, hammer in another hand....and then easy taps to get the pickup started....having to do this several times as the position is critical.
Oil pan gasket arrived in the mail, just awaiting time to get out there and do the repair. decided to leave the pump on and everything as is because i dont own an engine hoist and would like to see the truck on the road before the year is out. So, To be clear - Does the front differential have to come out to remove the pan?
Mods - you should be able to remove the oil pan without removing the front differential. Will have to move the steering link forward by unbolting both the pitman arm and steering box, shoving them forward. Will also have to remove the starter and the oil filter adapter. The engine will need to be rotated so that the front crank counterweights are up...then the pan should be able to be angled down and removed. Oh and you get to fight with those blasted transmission lines.
Looks like I will be doing this as well.
stonecoldsteele
11-06-2016 03:23 PM
Chevy33
04-17-2013 04:22 PM
