Erratic idle and poor fuel economy
So I tuned up the unit last weekend,no running issues,it was just due. Plugs,cap,rotor,wires. Ran much better(still does) the first tank showed a 4mpg increase! Then I have started having an extreme(2000 rpm)start issue and a very low(500 rpm) warm idle,also occaisionally it wants to run at 1500 rpm while no throttle applied while driving at low speeds.So the next tank mpg has me back at square one! IAC & MAF cleaning in order? It has been 60k since last done.Will inspect for vacuum leaks,but a tune up is usually non-invasive on these,so I find it hard to believe I caused this problem,especially since it performs so well otherwise! Any input? Thanks!
my rough idle was caused by a dirty egr valve. i took it off and sprayed the hell out of it with carb cleaner. after reinstalling the rough idle went away instantly, if youre going to do the iac maf and throttle body, i recommend hitting the egr valve
BlackMatter
Feb 16, 2012 10:27 PM
ned4spd8874
Feb 10, 2011 10:48 PM
Kenomee
14
Jan 29, 2011 12:01 AM
Lanel
Jan 16, 2010 07:22 PM
