Erratic timing
I just got a Matco MD1022 scan tool. While I was looking at the live data on my '95 Blazer, I noticed that the spark advance seemed erratic. At idle, it would vary between 5*-25*. (All the numbers were negative, i.e. -5, -15, etc. I'm assuming that's degrees BTDC.) Sometimes it would drop to zero.
I'm used to timing my old, points distributor 350. With the vacuum advance unplugged, it's a rock steady 12* BTDC, and it increases with rpm, up to the max amount. (35-38, I can't remember exactly.)
I have the EDI distributor, with the horizontal spark plug towers. I believe the computer controls the timing. Is it normal for it to vary that much? Maybe there is too much wear inside the distributor? The idle is very stable and smooth.
Sorry if this has been brought up before, I tried a search and didn't come up with anything.
It's normal not erratic. Timing is computer controlled and at idle, it is constantly being modified. It should be much more stable under load.
Comparing it with an old manual/vacuum system is like comparing an Atari to a PS3.
Doctorvette
Nov 5, 2012 11:57 PM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
disturbedgame
May 2, 2007 09:18 PM
