ERROR CODE PO442
Old Jan 22, 2009 | 06:14 PM
TAZ454's Avatar
TAZ454 is an unknown quantity at this point
Default ERROR CODE PO442
Once the problem is fixed does the cpu clear itself and erase the error code ? I changed the thermostat and then I got this code after about 10 miles ?????????????? new fuel pump about 100 miles ago
Old Jan 22, 2009 | 06:45 PM
Default RE: ERROR CODE PO442
Yes, the PCM will clear the code after a few drive cycles.
P0442 Explained will tell you what you need to know. You did not cause this code by replacing the thermostat.
Old Feb 4, 2009 | 07:52 AM
TAZ454's Avatar
I thought I had fixed the error,, found the gas tank vent hose had been cut when the gas tanks was removed for the r&r of fuel pump. replaced hose cleared cpu by disconnecting batt, after about 15 starts and 80 miles I hit a bump in the road and the error light came back on , here we go again !! are the connections at the tank push on ??
step66
Dec 31, 2010 08:23 PM
richblaz99
Sep 19, 2008 03:55 PM
Kage0113
Jul 5, 2008 07:28 PM
ceanern
Feb 27, 2007 07:43 PM
d10blaz
Oct 18, 2004 06:25 PM
