EVAP system
Old Aug 6, 2012 | 04:51 PM
Dadatone's Avatar
Dadatone is on a distinguished road
Smile EVAP system
Does any have a diagram for the EVAP system on 1998 2WD Blazer?
Thanks.
Old Aug 6, 2012 | 05:38 PM
Electrical or mechanical diagram? What problem are you having with the EVAP system? Is the Service Engine Soon light on? If so, what DTC is in memory?
Old Aug 6, 2012 | 06:00 PM
Dadatone's Avatar
Mechanical, please.
Right now, I'm just trying to gather information on the emission system. Earlier today I was driving through the ODB II monitoring cycle to see if I could clear some incomplete monitors before I took the truck in for it's inspections. I still have EVAP, catalytic converter and HO2 error. No codes, at least not now just incomplete monitors.
Old Aug 6, 2012 | 06:23 PM
Try using this General Motors Driving Cycle procedure. You don't need to do each step, only the steps necessary to complete the monitors that have not run and completed their tests. The EVAP monitor is the toughest one to complete: You must follow the instructions EXACTLY as indicated for the monitor to run and complete its test. If it doesn't run and complete the test, you missed something It says you can do the entire drive cycle in under 15 minutes, but that takes some serious practice After all of the monitors have run and completed their tests, the SES light should remain off, meaning no faults were detected. If the SES light comes on, post the DTC.
FYI: The fuel level must be between 15% and 85% for the EVAP monitor to run and complete, which means the fuel level sender must be working properly. For example: if the level sender has an open circuit, the fuel gauge will indicate a full tank of fuel and the monitor will not run. The monitor will report "Incomplete" until the level sender is repaired, and the monitor runs and completes.
EDIT: You'll need to do step 1 for the oxygen sensors, and steps 2 through 8 for the EVAP.
Old Aug 6, 2012 | 07:16 PM
Dadatone's Avatar
Okay, so, I should follow that bulletin to the letter.
Now, I just need to plan a route for tomorrows drive.
Thanks!
Old Aug 6, 2012 | 07:20 PM
Yes, follow it to the letter! You don't have to do the steps in order, but step 1 needs be done when the engine is cold.
Old Aug 7, 2012 | 06:43 PM
Dadatone's Avatar
Completed the O2 heater drive cycle this morning (which was the easiest ). Now, I guess I need to get some gas before I can perform the other two, or at least the EVAP cycle.
Glad there's a stretch of highway near me I can use to complete these monitor tests. I don't know what I'd do if I lived in the city.
Old Aug 7, 2012 | 07:54 PM
Yup, city streets do pose a problem really need a freeway for the rest of it.
PaulS 1960
Jul 26, 2011 10:05 PM
Wayner1011
Feb 16, 2011 10:03 AM
Indianarocker
May 18, 2009 04:42 PM
turretman
Jan 21, 2009 06:19 AM
hebelracing38
Nov 2, 2008 04:13 PM
