Evap vent solenoid testing
Old Jun 3, 2024 | 02:19 PM
  #111
jasondis's Avatar
jasondis is on a distinguished road
Also I have already checked the timing chain to see if it's skipped a tooth or stretched before. I've replaced the spider in this truck as well. I'm just wondering if it's the cheap China icm I'm using now that's setting it off ? I really don't want to but another one to fund out it isn't that. What your thoughts on that ? I have another cheap China one I can try quickly just to see but it might just be the same thing again.
Old Jun 3, 2024 | 03:01 PM
  #112
GeorgeLG's Avatar
Did you short the probes and zero the meter before that resistance test?
George
Old Jun 3, 2024 | 09:51 PM
  #113
jasondis's Avatar
You only do that on an analog meter. But yes I always touch the probes together to make sure everything in working order 😊 It's funny because the truck runs so much better now. I'm not sure what's setting this p0351 code off yet but it's gotta be something small.
Old Jun 3, 2024 | 10:20 PM
  #114
GeorgeLG's Avatar
Depends on the digital meter, here is my Extech:
That 0.4R reading is not as low as I expected. Most vehicle signal wires are 18 or 20 gauge. 20 gauge is about .01 ohms/foot and it’s a straight shot on that white wire, maybe 5 feet. The pcm does not like the voltage on that wire which can be the icm, pcm, or the wire/connectors.
George
Old Jun 3, 2024 | 10:47 PM
  #115
GeorgeLG's Avatar
Make sure that you have clean spark plugs gapped correctly and all the boots are on tight. Yes arcing can be bad wires but it can also be because the normal spark path is degraded. I forgot if we discussed a compression test?
Glad its running better.
George
Old Jun 4, 2024 | 06:52 PM
  #116
GeorgeLG's Avatar
I have been thinking about your ignition leakage problem. We have already covered many of the potential causes:
  1. Bad ignition wires
  2. Bad timing
  3. crank sensor issues
  4. Wiring
  5. ICM
  6. Coil
  7. Plug condition (poor gap)
  8. Compression
One thing that we have not talked about is the ground return path which is through the block to the battery. Make sure that your block grounds are clean and tight. Any increase in the spark path resistance can force the spark to find an esier path to ground
George
Old Jun 7, 2024 | 12:14 AM
  #117
jasondis's Avatar
Thanks George I took your advise and I cleaned two grounds today. Ground to frame and ground to engine ... negative cable. I know theres one under the battery tray but that shouldnt be an issue. I have to try to take a look at the back of the block but I already know it next to impossible to see.
Old Jun 10, 2024 | 12:13 AM
  #118
jasondis's Avatar
I've been doing some research on the p0351 code and I came across a video the guy says that the last number corresponds to the cylinder but I think he was working on motor that has individual coil packs. Does it work the same for a distributor ? Do the p0351 mean cylinder 1 p0352 mean cylinder 2 and so on ?
Old Jun 10, 2024 | 12:53 AM
  #119
GeorgeLG's Avatar
No, on our single coil, single ignition control wire system this is the only code for a voltage fault on that wire.
George
Old Jun 10, 2024 | 03:06 AM
  #120
jasondis's Avatar
Ya that's what I thought . I want to throw another ground on the icm wire to negative battery.Do you think I'll create a ground loop or should I just cut the wire and if it doesn't help soilder it back up and heat shrink it ? What gauge is that wire 22 ?
