Exhaust routing help
What's the difference between a 96 2door 4x4 exhaust routing and a 95 2 door 4x4. I know that in 96 they switched engines but was the exhaust different?
hmm, im not 100% sure but i dont think they changed the routing, seems like way to much unnecessary engineering to change the positions of everything else.....now the mount locations and brackets that would bolt onto the headers, cat might have changed.....i know in my 88 s10 the exhaust came out the drivers side of the engine in my 4cycl, then went behind the engine and across to the passenger side of the vehicle, then straight back and out the side behind the rear wheel on the passenger side, its the same route for the stock exhaust on my 2000 2 door, with the exception of the y pipe as its a v6.
So routing should be the same, but couldnt tell you if the mounts are the same and brackets in the same locations
rsheltro
12-26-2008 09:11 PM
