Failed emissions
Old Nov 11, 2014 | 04:58 PM
MiniWall9's Avatar
MiniWall9 is on a distinguished road
Default Failed emissions
So I have a 95 blazer. Have had some work done since it failed the first time I took it. I replaced the spider, map sensor, idle air valve, catalytic converter, O2 sensor. I took it Monday & it failed.
Hydrocarbons were 3.01
Carbon monoxide was 62.47
I really don't know what else to do, to get it to pass. Would like some input on what should be done in order to fix those problems, thank you.
Old Nov 11, 2014 | 10:55 PM
cleburne red's Avatar
How long has it been since you did an ignition tune up? Plugs, wires, cap, and rotor? I'm no expert, but the HC, and maybe CO sounds like it's not burning all the fuel? You already replaced a bunch of stuff, so there can't be many things it could be
Old Nov 11, 2014 | 11:20 PM
MiniWall9's Avatar
I haven't done any of that. I've had this truck for a year & have been told I needed to do different things in order to get it to pass. Which is why I got the spider, cat, idle air valve & map sensor replaced.
Old Nov 13, 2014 | 11:02 PM
That would be my guess, ignition related. When I was getting my blazer up and running, after I bought it, I had no idea how old the ignition components were, so I went ahead and bought AC Delco cap, rotor, wires, and plugs.
Follow the advice you'll see here quite often, use AC Delco/Delphi parts only. If you check out rockauto.com, you can usually get name brand parts for less than the junky autozone house brand.
Old Nov 14, 2014 | 05:23 AM
newguy's Avatar
autozone should have ac delco / delphi but it may cost more
dannyek7
Jun 4, 2010 07:53 PM
edkimdavey
Aug 8, 2009 07:57 PM
dyeraudio
Mar 7, 2009 07:15 PM
Spartan66
Jul 3, 2008 12:11 PM
Blahman20
Apr 21, 2007 07:06 AM
