Failed Gas Pressure Leak Down Test
Old Jun 23, 2013 | 12:59 PM
ShadowZone's Avatar
ShadowZone is on a distinguished road
Cool Failed Gas Pressure Leak Down Test
Hi Blazer Forum
I have a 2000 Blazer ZR 1 it recently had both CAT'S fail and replaced. I have been getting error codes - 0172, 0175 & 0300. Left & Right bank running rich & general misfire. So I ran a Leak down test on the fuel rail. and it failed badly. It jumped up to 60 PSI held for about 5 seconds and dropped to 0 quickly. So I am thinking it has to be stuck injectors or leaking hoses or regulator.
I am going too pull the injectors and pressurize the fuel system and see if I can spot the problem. A spider goes for 300+, each injector goes about 70-80 or should I clean injector and replace seals, more work but alot cheaper.
It runs good, idles rough and hard 2 start when its hot, gas mileage is about 15 to 18 highway.
Any advice will be greatly appreciated, you were all very helpful last time, will post back with results.
Thanz Shadowzone
Old Jun 23, 2013 | 02:08 PM
mr.vls's Avatar
I would do the MFI upgrade. Eliminate poppets and everything is brand new. I just did this on my 2000 GMC Jimmy. See the link below:
Amazon.com: Delphi FJ10565 Fuel Injector: Automotive Amazon.com: Delphi FJ10565 Fuel Injector: Automotive
scode67
May 24, 2010 10:59 PM
edkimdavey
Aug 8, 2009 07:57 PM
dyeraudio
Mar 7, 2009 07:15 PM
kerander
Feb 8, 2008 02:49 AM
Blahman20
Apr 21, 2007 07:06 AM
