Fan Clutch?
Old May 15, 2008 | 10:22 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default Fan Clutch?
Ive looked around and seen to do the spin test to tell if its bad or not. I can spin the fan by pushing it but as soon as I stop pushing it will instantly stop. Secondly the fan runs at cold startup and at all rpms. Is this a bad fan clutch? Oh and also if it is the clutch does that seriously cost ~$80 for that simple looking thing.
Old May 16, 2008 | 07:01 AM
Coyote's Avatar
Coyote is an unknown quantity at this point
Default RE: Fan Clutch?
It sounds like it is, also check side play by grabbing the fan at 3 o'clock and 9 o'clock positon and see if you have to much play. If it wiggles its time for a new one. Not sure about the cost check auto parts store.
Bob
Old May 16, 2008 | 08:50 AM
rriddle3's Avatar
ORIGINAL: portcqb
Genuine AC/Delco fan clutchcan run even more than that.
Old May 16, 2008 | 09:32 AM
portcqb's Avatar
Yah its like 120 for a delco, is there anything I can do to free up the clutch like cleaning it or anything or is the only option to screw it off and put a new one on.
Old May 16, 2008 | 09:41 AM
rriddle3's Avatar
Either replacethe factoryfanwith an electric fan, a direct drive fan, or replace the clutch on the factory fan. I recommend replacing the clutch.
Old May 16, 2008 | 10:25 AM
portcqb's Avatar
Isnt it basically a direct drive fan right now? There is no play at 3 and 9.
Old May 16, 2008 | 10:59 AM
rriddle3's Avatar
Yeah, I guess it is.Direct drives are noisier and less fuel efficient. The factory fan set-up is pretty good. If you want to save a little money and add more work you could change the whole fan assembly for another type, but changing the clutch is pretty easy and simple.
Old May 18, 2008 | 07:13 AM
drperry's Avatar
And you'll never find an e-fan setup that pulls as much air as the stock fan
The stocker has been reportedly able to pull in excess of 4000 CFM.
gitch93
Jul 23, 2013 08:06 AM
cheesequaker
Apr 25, 2012 01:44 PM
85kulan
Oct 4, 2011 09:51 AM
MintyMadness
Jul 13, 2011 12:37 AM
Red03
Sep 25, 2008 08:37 PM
