Fender and possible break line
Old 12-26-2012, 06:45 PM
Fosse's Avatar
Fosse is on a distinguished road
Default Fender and possible break line
I got in an accident about a month ago and finally got notice today they are sending me a check to get my truck fixed. So my question is, how hard is it to put a new front passenger side fender on? I have a friend that works at a junk yard and can probably get that for real cheap if not free. Also I think the break line might have been cut or something. I just noticed some fluid dripping right behind the tire. Would that be a hard fix for someone not too mechanically inclined or would I be better off taking it to a shop for that?
Old 12-26-2012, 07:11 PM
Irocz327's Avatar
Irocz327 will become famous soon enough
Well it depends on how mechanically inclined your are. Have you ever done a motor pull/ major engine work or suspension work (ball joints, hub etc)?
Also can you post some pics of the fender & where the fluid is dripping from? That would make it easier for us to tell ya how hard it would be to fix it yourself.
Old 12-26-2012, 07:43 PM
Fosse's Avatar
Haven't done any of that. Pretty much have just replaced starters and radiators. I'll try and get up a little early before work tomorrow and take some pictures. Thank you
Old 12-26-2012, 07:50 PM
Irocz327's Avatar
Hey it shouldn't be to terrible to do. The fender is just a game of memory depending how bad the fender is it should just be a matter of unbolting this & moving them back to same spot on the new one. & brakes aren't bad at all. My guess is if its leaking you prolly ripped the rubber line that just a matter of tracing it until you find the flares & undoing the nuts & any clamps to hold it down. If its a metal line it can be easy or Harding depending on where it's broke & if it can be patched or has to be replaced.
It's all hard to say with out pics thou.
Old 12-26-2012, 08:08 PM
Fosse's Avatar
The fender definitely needs be replaced. I have a Haynes manual and reading through it, doesn't seem hard, just kind of tedious. And I'm not positive about the break lines. I'll take pictures tomorrow and try and find where I saw the drips coming from
Old 12-27-2012, 12:13 PM
Fosse's Avatar
I was only able to get a picture of the body damage. I'll have to wait til tomorrow when I can get it up an the tire off to try and find the leaking fluid
Old 12-27-2012, 12:51 PM
abig84's Avatar
the biggest issue you will probably run into is getting that fender off due to the metal being smashed around the bolts. when i got into a accident i couldnt just unbolt my bumper i ended up having to cut it into a bunch of pieces to get at the mount bolts
Old 12-27-2012, 01:05 PM
newguy's Avatar
Take pictures of everything before you start taking stuff off and as your taking it off. Rebuilt a tranny that way
Old 12-27-2012, 02:10 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
if you have done starters and radiators, you will be able to do the fender and the brake line. pretty cake
Old 01-04-2013, 02:08 PM
Fosse's Avatar
Sorry for the bad pic. But this where the fluid was leaking from. Pretty sure it's the brake line
Quick Reply: Fender and possible break line
