few questoins about my jimmy
Old Feb 5, 2010 | 09:58 PM
gmc97jimblaze's Avatar
gmc97jimblaze is on a distinguished road
Default few questoins about my jimmy
1997 gmc jimmy 4.3L
1> what kind of plug can change the old one with ?
2> what is the gap for the plugs?
3> whats the best way to get to the plug thats on the Driver side Under the steering arm?
4> whats the firing order 246,135?
5> where is that o2 senses located, and what would happen to my truck if i had a bad one.
i have many more questions but that's it for now
Old Feb 5, 2010 | 10:12 PM
hubert hefner's Avatar
hubert hefner is on a distinguished road
Originally Posted by gmc97jimblaze
1997 gmc jimmy 4.3L
1. Ac Delco #12
2. .060
3. though the fender well
4.165432
5. there are 3, One on each pipe coming off of the manifolds and on after the cat. fuel economy goes down and the check engine light comes on.
hope this helps.
Old Feb 5, 2010 | 10:14 PM
rriddle3's Avatar
1. Or AC/Delco Double Platinum #41-993 factory pre-gapped at .060.
3. This has been discussed many, many times. Please use the 'search' function for '#3 spark plug', etc.
Old Feb 5, 2010 | 10:32 PM
wow how do you tell what one is bad then ? or do replace them all there like 60 bucks a pop
Old Feb 5, 2010 | 10:35 PM
is the check engine light on? it will throw a code if the o2 sensor is bad. may have a clogged cat.
Old Feb 6, 2010 | 07:37 AM
Just to clarify, a '97 will likely have four (4) O2 sensors.
If you do need to replace an O2 sensor, use AC Delco sensors only. In my experience, AC Delco sensors last longer than others. But do diagnose the problem first. It is never a good idea to just throw parts at a problem.
flipzat
Lifting Tech
Feb 12, 2010 01:26 PM
Eff10
23
Jan 28, 2010 05:37 PM
mr.vls
Apr 15, 2008 07:46 PM
vagnozzi
May 6, 2007 01:17 AM
