First post...need help troubleshooting
Old Mar 9, 2017 | 04:04 PM
Toothpick76's Avatar
Toothpick76 is on a distinguished road
Default First post...need help troubleshooting
Hey guys this is my first post because my 1998 jimmy has me scratching my head for the first time in a while. First the cat converter has been one for a few months I just haven't been able to afford it but it just started doing this. At an idle, cold or warm, the idle will bump every 5 or 6 seconds. When I shift into any moving gear I can pop the throttle while on the brake and it shimmies really bad like its not keeping up with throttle response. And it also surges a little bit pulling hills or accelerating at low rpms. Its only getting 15mpg now. I've replaced fuel filter, TPS, maf sensor, and I ran system cleaner through it. Also there are no vacuum leaks I can find. Any help? My thoughts are fuel pump or a new catalytic...but an open mind would help more. Thanks.
Old Mar 9, 2017 | 04:15 PM
Ronald Tillett's Avatar
Ronald Tillett is on a distinguished road
Default 95 blazer surging
95 Blazer 4.3 surges bad only after warm up. fuel pressure gauge goes from 52 psi to 60 psi rappedly.
Old Aug 14, 2017 | 01:28 PM
jimspahr@msn.com's Avatar
Describe 'idle will bump every 5 or 6 seconds'. If it surges up and down at idle, that could mean a bad IAC/ Idle Air Control. That is a fairly easy and inexpensive thing to replace. Also check your MIL / CEL codes and post them here. You could have a lazy O2 sensor / poor gas mileage.
Old Aug 14, 2017 | 04:50 PM
Strangerock's Avatar
Strangerock is on a distinguished road
Damn , mine runs great and I only get 15 mpg.
Old Aug 14, 2017 | 05:37 PM
newguy's Avatar
yeah pretty normal
HamToast
15
Jan 16, 2014 02:22 PM
cargirl81
Mar 20, 2013 11:35 AM
shizzles42
Mar 28, 2012 08:40 PM
garciamode
Aug 7, 2010 11:56 AM
mlonas
Jun 25, 2008 10:01 PM
