Flex fan on 99 S10 Blazer 4.3L ?
Old 08-19-2010, 02:36 PM
davedidit's Avatar
davedidit is on a distinguished road
Default Flex fan on 99 S10 Blazer 4.3L ?
I have a 7 blade flex fan and A 2" spacer
is the fan clutch on A 4.3 L 99 S10 Blazer
mount to the water pump like a 5.7 L small block
with 4 bolts to the water pump
Old 08-21-2010, 11:03 PM
davedidit's Avatar
bump
Old 08-22-2010, 06:17 PM
Thread on clutch.
So you want to replace the very efficient thermo-viscous fan clutch with a flex fan?? What are you hoping to accomplish?
Old 08-22-2010, 06:31 PM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
A very noisy fan?
Old 08-22-2010, 08:23 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Kyle-am I reading this right-a 99 S-10 blazer does not have a bolt on fan-isn't the question if a 99 has a four bolt-on fan? JP....guess the question is why..
Old 08-22-2010, 08:27 PM
Yep, you are exactly right. Thread on clutch. I knew that... Don't know where my brain was on that. Wrong info removed.
But what I might have been thinking was how to install a flex fan. There are 4 bolts that bolt the pulley on. If the spacer were to have a large enough ID to allow for it to go over the threaded end of the water pump, it would work. Still leaves the "why".
Old 08-22-2010, 09:29 PM
Wouldn't you have to find a reverse direction fan?
Also putting a standard short nose pump wont work either as its a reverse rotation, unless they make one thats reverse direction. ..
The viscous clutch setup works pretty darn good if you ask me.
Old 08-25-2010, 12:22 PM
davedidit's Avatar
Bummer I wanted to use the flex fan they pull alot of air
with the summer temps reaching 117 in Vegas
is their a adaptor or someway I could use it
Old 08-25-2010, 04:25 PM
Flatearthman's Avatar
Flatearthman is on a distinguished road
OMG throw the flex fan in the garbadge they worked great on old hot rods 30years ago
Old 08-25-2010, 04:31 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
what about a electric fan conversion to save a few pennies on gas? has anyone done this yet cause i was thinking about trying it.
Quick Reply: Flex fan on 99 S10 Blazer 4.3L ?
