flushing the brake system
Old Jul 26, 2012 | 09:10 PM
toms2000blazer's Avatar
toms2000blazer is on a distinguished road
Post flushing the brake system
How do I go abouth flushing the brake system on my 2000 Blazer 2WD. I have a press bleeder available if needed. Do I need a scanner to flush the system if there is no air in the system?
Old Jul 26, 2012 | 10:23 PM
abig84's Avatar
should be able to do it by just doing the brake bleeding procedure. have someone pump the brakes a few times and hold it and crack the bleeder open then close it and repeat. go around and do each bleeder one at a time til you get the clean fluid out. make sure you dont let the master go dry though. and if you live in north where salt is sprayed down, start spraying down those bleeders asap they tend to break off
Old Jul 26, 2012 | 11:59 PM
50lb_cat's Avatar
+1, also work your way from the furthest wheel away from the master to the nearest.
BigDaveH
Apr 1, 2014 10:12 PM
marklar
May 28, 2011 09:27 PM
Blazin 4x4
Sep 21, 2005 05:02 PM
Blazin 4x4
Sep 21, 2005 01:26 PM
Blazin 4x4
May 25, 2005 01:57 AM
