Flushing/cleaning the coolant system on a 2000 Blazer LS
Old Oct 5, 2016 | 04:40 AM
TheSaint's Avatar
TheSaint will become famous soon enough
Default Flushing/cleaning the coolant system on a 2000 Blazer LS
I replaced the water pump on my car because coolant started to sip out the lower drain hole
I also took out the expansion tank to clean it since it was so diirty because of rust water and Dex Cool residue
Yesterday i filled the coolant system 2 times usin clean water, starting the engine in between and adding clean water in the radiator until the engine was up to norma temperatue and dlushed it out again
After the engine cooled down i added Valvoline VPS radioator flush using to clean the cooling system properly and started the engine at let it idle up to normal temperature and let the engine run for 20 minutes as the instructions on the radiator flush says
But when i drained th car after the radiator dlush the water was so dirty that i had to fill the car up with clean water, let the engine run up to normal temperature and then drained the water but still the water was to dirty for my liking
So today i have to add another bottle of Valvoline VPS radiator flush and clean water, let the engine idle for 20 minutes before drain and the go over and do the same process once more using clean water and hope that the water is clean enought that i can fill the coolant system with anti freexe and clean water
Is it the Dex Cool that GM use that is the reason that the cooling system on my car was so dirty?
When adding the new coolant i am using red Valavoline Max Life anti freeze
Old Oct 5, 2016 | 06:41 AM
rriddle3's Avatar
No, DexCool was not and is not the issue. We have had this discussion many times here. The problem was that back then the cooling system design was not the type that kept tiny amounts of air out of the system and combining air and DexCool is not good, plus at one time, coolant fluids were not always compatible with each other and they did not combine well with DexCool. Also, some people still believe that DexCool can go 100,000 miles without replacement.
GM still uses DexCool along with correct system designs very successfully in their vehicles.
Davecubs14
Feb 24, 2015 07:19 AM
BigDaveH
Apr 1, 2014 10:12 PM
toms2000blazer
Jul 26, 2012 11:59 PM
benthm7
Apr 17, 2011 09:29 PM
Blasir
Apr 23, 2007 01:57 AM
