Fog lights
Old Dec 16, 2009 | 06:36 PM
mav06's Avatar
mav06 is on a distinguished road
Default Fog lights
I have a 2000 4x4 4door and it came with the standard Turn signals and i was wondering if it had a standard wiring harness for factory fog lights by the turn signal? I was wanting to change them out so i could roll in some style just curious.
Matt
Old Dec 16, 2009 | 06:57 PM
It's been discussed quite a bit in the past. It isn't as easy as plugging in the components. The BCM will have to be reprogrammed to enable fogs.
Old Dec 16, 2009 | 07:13 PM
mav06's Avatar
Really, dang so would you just suggest getting ones i can just mount onto the bumper and one day to the Brush guard. And what is the bcm. I should probably just do some searching lol thanks
Matt
Old Dec 16, 2009 | 07:43 PM
mav06's Avatar
Ok so i guess i need help using the search feature, I have not found a thing unfortunately. help lol
Matt
Old Dec 16, 2009 | 08:45 PM
ABN31B's Avatar
SEARCH HELP
good luck
Old Dec 17, 2009 | 12:01 AM
foxxie's Avatar
I did this but our blazers down here came with rear fog light switch, hope it helps.
https://blazerforum.com/forum/showth...t=37162&page=9
Old Dec 17, 2009 | 05:08 AM
Bad Attitude's Avatar
Bad Attitude is on a distinguished road
Matt
My 2000 blazer has factory fogs and for the rear had high visibility tail lights but I have used those bulbs for extra brake lights
Guess us Kiwi's are lucky enough to have all the extra bits like wider flares (just for georgesblazah) and headlight washers and fancy nerf bars OH yeah and the steering wheel on the right hand side where it should be LOL
Old Dec 19, 2009 | 10:22 PM
mav06's Avatar
So i tore off my grill and everything looking for the wireing harness but to no avail. i did find one little wire on the passenger side. It had two wire going to it. But it wasen't the right connection for the fog light. Then i also found a wire were the Intake box would be, it was below it and had a green cap on it and was mounted to the radator support on the engine side. It had a few wires going to it also. No idea what these are for any ideas. So it lookes like i get ot pull some wire. Any suggestions were to pull it through the firewall?
Matt
SWANNERZ
Aug 13, 2014 05:05 PM
Benedict1337
Dec 10, 2010 08:30 AM
tmurph01
Apr 13, 2010 02:27 PM
R2P
Nov 1, 2009 08:03 PM
ewingmh
May 13, 2007 07:21 AM
